product picture
InSinkErator F-2000S Water Filter System Plus for Clean Tasting Water, Includes
pin
Insinkerator, F-2000S, Under Sink Filter, Water Filtration,N/A The F-2000S Water Filtration System Plus Is Designed For Exclusive Use With Insinkerator Water Dispensing Systems. System Includes: Filter Head Bracket, F-2000 Replacement Filter, Two Polyethylene Tubes, Quick-Connect Fitting, Two Mounting Screws, 1/4 Compression Fittings Reduces Particulates, Chlorine Taste And Odor Plus Cysts, Lead, Mercury, Asbestos, Benzene, Atrazine, 2, 4-D, Lindane, Carbo Furan And P-Dichlorobenzene, For Clean-Tasting Water - Nsf Standard 42 Certified For Quality Assurance - We Come To YouA 1-Year In-Home Limited Warranty (Excludes Filter Replacement Cartridges) - Designed For Exclusive Use With Insinkerator Water Dispensing Systems - Filter Head Bracket Compatible With Only F-1000 And F-2000 Replacement Filters - Recommended 6 Months Replacement For Optimal Performance - Twist-And-Lock Design For Quick-And-Easy Filter Changes - Sanitary Quick-Change Filter Cartridge - Automatically Shuts Water Off When Filter Cartridge Is Replaced - Includes Qty 1, F-2000 Filter -
Get the Lowest Price
